 Post subject: Taskbar toolbars
PostPosted: Sun Jul 31, 2005 9:08 pm
I use Copernic Desktop search. This normally adds iteslf as a toolbar on the Windows taskbar. It doesn't seem to appear under NextStep.
Have I missed something or is there some other way to keep using it??
Steve
PostPosted: Sun Jul 31, 2005 9:45 pm
Temporarily disable NextSTART task management and drag the Copernic toolbar out of the Windows taskbar and onto the desktop. Unfortunately that is the only way you can keep on using it.
PostPosted: Sun Jul 31, 2005 9:51 pm
OK thanks. I run dual monitors so I can leave it at the bottom of the 2nd one.
S
Users browsing this forum: Amazon [Bot] and 191 guests
