 Post subject: Saving WorkShelf fonts in Themes does not stick !
PostPosted: Sun Jul 31, 2005 8:59 pm
I've been customizing some themes & , at your suggestion, have been resaving the themes. It has worked up to a point. I cannot seem to be able to make font (icon text font) changes (type & color) stick. When I return to a theme, the fonts have returned to their original form. Cannot figure out what I am doing wrong.
Later: think I found the problem. I was configuring & resaving Workshelf and then going from theme to theme in NextStart. I now see they skin independently.
PostPosted: Mon Aug 01, 2005 12:36 pm
Ah, glad you found the problem. You just saved me from making a long search in the save routines looking for problems. :D
Keep in mind that altough being part of a suite, NextSTART and WorkShelf are completely individual programs and can function as such. Also, remember that unless you actually save the theme (by pressing the Diskette with a Pencil button in the Themes Management tab), changes will only last UNTIL you switch to another theme, then they are lost.
Users browsing this forum: Bing [Bot] and 182 guests
