 Post subject: New theme for WS module.
PostPosted: Mon Aug 15, 2005 12:15 am
It does not work for me. When I R-click on a module & select NEW MODULE THEME, either:
1. nothing happens or
2. NS theme changes, WS theme becomes black, & module theme does not change.
Any suggestions?
PostPosted: Mon Aug 15, 2005 6:28 am
Hmmm, working here, at least with the Atomic Clock desktop module. What theme are you trying to change to and in what module (i.e. does this happen with ALL the modules? Does this happen with all the themes?)
Also, open WorkShelf Preferences, navigate to the Themes tab, and click on the Theme Options button. Do you have any modules with Themes set to locked?
PostPosted: Mon Aug 15, 2005 2:22 pm
No themes are set to locked.
This is a strange phenomenon: it only is a problem with the weather module. When I try to change the theme of the weather module (from ANY theme to ANY other theme), ALL module themes get changed along with the NS & WS themes with the WS tabs becoming black!!!
With the clock & CPU modules, behavior is normal.
PostPosted: Mon Aug 15, 2005 2:38 pm
Ok, that last clue is all I needed. It's a BUG! :shock:
Anyway, fixed for next version, thanks. :D
PostPosted: Mon Aug 15, 2005 2:56 pm
There is something about my ability to discover software bugs. I do it ALL the time!!! :D
PostPosted: Mon Aug 15, 2005 4:03 pm
That's because you try everything... :D
You're probably the nightmare of lazy programmers, but since I'm not one of those... I like it. :wink:
PostPosted: Mon Aug 15, 2005 8:48 pm
Amen !
Users browsing this forum: Amazon [Bot] and 195 guests
