 Post subject: Systray Icons on winstep?
PostPosted: Thu Oct 09, 2008 7:24 pm
So i have been trying but have not found a way to get the systray to become either a tab or show the items running on my computer (like the messenger icon, logmein icons, etc.).
Anyone able to have this running? or a guide to create a tab for them?
Thanks.
PostPosted: Fri Oct 10, 2008 4:17 pm
Sorry, you got me a little bit confused here.
You want to display the systray (system notification area, e.g. the icons at the lower right of the taskbar, next to the clock button) in a Shelf *and* you want it to display running tasks? It's that last part that threw me a bit off... Windows controls what appears on the systray, not Winstep.
Anyway, regarding having the contents of the systray on a shelf, that is not possible, sorry. The next best thing you can do, however, is detach the systray from the NextSTART Startbar and have it float anywhere on the screen.
PostPosted: Thu Oct 16, 2008 1:51 pm
My apologies for not being clear....Yes what i would like is either a docklet? or a bubble, etc...anywhere where i can see my lower right hand icons such as the clock, the wireless connections, random messengers when minimized, etc...
Currently the only way for me to see them is tho have the taskbar from windows showup, which is what i do not want while using your product.
Thanks for your answer.
PostPosted: Thu Oct 16, 2008 2:19 pm
Can you please send a screenshot of your desktop, with NextSTART Preferences open on the Tasklist and Systray Preferences tab, to the Winstep support address (or post it here)?
Users browsing this forum: Amazon [Bot] and 217 guests
