 Post subject: Normal Windows Start Menu Association *Need Help*
PostPosted: Fri Jan 23, 2009 1:32 pm
Well whenever I use the normal start menu for NextStart, the start menu appears with a few black areas. I dont know if this is a bug or not. But I prefer to use my normal windows start menu as it has a style to look like the vista start menu.
However, I have also tried using the unmodified windows start menu, but with still no prevail it still has black areas.
Ill post a photobucket picture of this encounter and advice on what to do would be greatly appreciated.
-Matt
Image[/img]
PostPosted: Fri Jan 23, 2009 10:16 pm
I've seen the same thing. I have no fix however.
 Profile ICQ
PostPosted: Fri Jan 23, 2009 11:56 pm
Looks like a video driver bug of some kind... What are your graphic cards? Are you running WindowBlinds as well? If so, does the issue go away if you exit WB?
PostPosted: Sat Jan 24, 2009 1:06 pm
I have an ATI Radeon 2400 XT 256mb VR. I'm pretty sure that I have the very latest version of the driver from ATI.
Any fixes for this whatsoever?
-Matt
PostPosted: Sat Jan 24, 2009 6:30 pm
Maxy, what are you running in that screenshot? It looks like the public beta of Windows 7... or is it a WindowBlinds skin?
Users browsing this forum: Amazon [Bot] and 204 guests
