 Post subject: Problems with item removal dialog (again)
PostPosted: Sun Mar 22, 2009 12:23 am
I'm trying to remove the shorcuts mentioned in my last post, and now the Confirm Item Removal dialog appears BEHIND the subdock I'm trying to delete from. That's problem 1.
Problem 2 is that the confirm dialog defaults to "no". I've never (ever) clicked on "no", because the dialog can only be accessed by deliberately right-clicking the icon and selecting "remove from dock". So if I've gone to all that trouble to bring up the dialog, I don't want to be asked if I'm sure! (I'm ALWAYS sure, which is my biggest problem outside of computers :oops: )
So can we get an option NOT to prompt for subdock removal when the dialog is accessed from the item menu? That would be a great help - I use it rarely, but every time I do, I get frustrated with the prompting.
PostPosted: Sun Mar 22, 2009 12:34 am
Sure! Right click the Recycler Module, open Recycler Settings and uncheck 'Confirm File Deletions'. :D
Not exactly. You also get that same prompt if you drag & drop an item into the recycler bin module (or use the DEL key on the Shelf - I don't think keyboard navigation works properly on docks, though).
Is your dock's Z-Order set to 'Always on Top'?
PostPosted: Sun Mar 22, 2009 5:29 am
Thanks Jorge... To answer your questions :
- I don't use the recycler module at all. But I've now enabled it long enough to disable the prompting. Thanks so much for that tip!
- Yes, my dock's z-order is "always on top".
I haven't installed the newest release yet, I'm planning a reboot tomorrow afternoon (Monday PM for me, maybe AM for you). I'll let you know if that fixes the display thing.
PostPosted: Sun Mar 22, 2009 1:17 pm
Ok, don't forget to first upgrade to 8.11 then to download and install 9.3 beta 2 on top of it. :D
I'm going to check Z-Order issues now... Thanks! :D
Users browsing this forum: Amazon [Bot] and 212 guests
