 Post subject: Saving weather module data
PostPosted: Mon Apr 20, 2009 7:38 pm
Greetings,
first, i am a new user of Winstep Xtreme and purchased it yesterday.
i tried a few competing products but Winstep beat them all in user friendliness and features.
my problem is: i add Wind speed and direction to the weather module but when i change theme and come back the wind data is not saved.
i tried saving the theme itself but no luck.
how do i go about saving my setup?
tnx,
vincent
PostPosted: Tue Apr 21, 2009 10:02 pm
Hi Vince, and thanks for registering Winstep Xtreme! :D
The theme needs to be re-saved after your changes. Since you say you did that, perhaps you saved it in NextSTART Preferences instead of WorkShelf Preferences?
Because NextSTART and WorkShelf are two independent applications, saving a theme in the Theme Manager tab of WorkShelf Preferences will only save those settings related to WorkShelf (docks, shelf, desktop modules), while saving a theme in NextSTART Preferences will only save those settings related to NextSTART (menus, startbar, hotspot buttons).
Hope this helps,
PostPosted: Tue Apr 21, 2009 11:12 pm
tnx jorge! :)
Users browsing this forum: Amazon [Bot], Bing [Bot] and 174 guests
