 Post subject: NextSTART Preferences in a WinStep Tab
PostPosted: Thu Mar 11, 2010 7:37 pm
While using WinStep Extreme, I would like to be able to left click on an icon in one of tabs on my WinStep shelf to bring up the NextSTART preferences. I can get the WinStep preferences, but not the NextStart. Is this possible?
PostPosted: Fri Mar 12, 2010 4:10 am
WorkShelf and NextSTART are completely separate applications, so normally the answer would be no.
However, to prove how powerful Xtreme is, this is actually possible:
Essentially what you have to do is create a new NextSTART hotspot associated to the 'NextSTART Preferences' Internal Command. Now, in WorkShelf, you add a new item of type 'NextSTART Hotspot' to the Shelf and tell it to run that particular hotspot.
If you need a step by step description on how to do this, I'll need to know what version of Xtreme are you running. :D
PostPosted: Fri Mar 12, 2010 11:02 am
Jorge -
Got it. Had not thought of using a hot spot for a tab item, works just like I want it to.
Users browsing this forum: Amazon [Bot] and 185 guests
