 Post subject: Problem with Nexus
PostPosted: Sun Sep 06, 2009 9:39 pm
Hello,
I' have a problem with Nexus, I' noticed that when Nexus is posted on my desk I' have a problem with the file which are on the desk, with each time I all alone select a file on the desk it not select, it is impossible to select a file on the desk when the Nexus bar is launched, and it's impossible to remove the files which are on my desk, I am obliged to desactivated Nexus to be able to remove my file on the desk. How can one regulate this problem ?
thank you
PostPosted: Tue Sep 08, 2009 11:43 pm
Did you have this problem from the begining? If not, did you add or change anything in the default Nexus configuration? A screenshot of your desktop with Nexus visible might be of some help too...
Thanks,
PostPosted: Wed Sep 09, 2009 6:06 am
Yes i have this problem from the begining,
if I make a imprim screenshot that will not help you much because it would be necessary that I make a video so that you see the problem, and I cannot make, on a screenshot you will not see the problem
PostPosted: Wed Sep 09, 2009 6:26 am
What happens when you right click on a desktop icon then?
PostPosted: Wed Sep 09, 2009 7:54 am
it precisely occurs anything, impossible to select a file
PostPosted: Wed Sep 09, 2009 3:53 pm
I don't think anyone else has this problem (or someone would probably have already said something) which makes it system specific, and I am unable to reproduce it here, sorry... If I can't reproduce it, I can't know what is wrong and therefore fix it.
In fact, it's the first time I've heard of such a problem... Perhaps something else is interacting with Nexus and creating this issue? You'll have to do some detective work yourself...
Users browsing this forum: No registered users and 181 guests
