 Post subject: Portable Nexus
PostPosted: Tue Nov 03, 2009 8:32 pm
Hi guys.
I used Ceedo (http://ceedo.com) to make a portable Nexus for my usb drive which works fine except for the fact that every time usb drive's letter changes, all shortcuts i put in Nexus become unavailable.
I know that is because all the shortcuts are absolute (example: "E:\folder\file.txt"). I tried to use a relative address (example: "\folder\file.txt") but that wont work.
Any ideas?
Regards, BjarkiMTB.
PostPosted: Thu Nov 05, 2009 6:42 am
Change the usbdrive letter ;-)
If you don't correct an error you have done a second one
PostPosted: Thu Nov 05, 2009 9:45 am
Cute, Thorsten. :P
Seriously, I'll look into this as soon as I have the time, BjarkiMTB.
PostPosted: Thu Nov 05, 2009 5:22 pm
Cute, Thorsten. :P
Thank you!
I also experimented with System Environment Variables (%ProgramFile% etc.) and made my own variable that had "E:" as a value, but that didnt work either. :?
Users browsing this forum: Amazon [Bot] and 226 guests
