 Post subject: Right-click on WorkShelf Freezes the WorkShelf
PostPosted: Tue Dec 29, 2009 1:32 am
I am using the latest beta version. When I right click on an application shelf entry in Workshelf, it freezes. I have to force close workshelf and start it again. This does not happen if the shelf entry is a desktop module.
I am using Windows XP Pro SP3.
PostPosted: Tue Dec 29, 2009 1:41 am
I would say you have a buggy/corrupted shell extension installed on your system (one that adds an entry to the Explorer context menu of files).
Try the following: open WorkShelf Preferences, go to the Advanced tab, click on the Advanced button and clear the 'Show full right-click context menu options'. Does that solve the problem?
PostPosted: Tue Dec 29, 2009 3:36 am
Yes. It did work. Thank you.
Users browsing this forum: Amazon [Bot], Majestic-12 [Bot] and 188 guests
