 Post subject: Question about file browser
PostPosted: Thu Jan 19, 2006 1:23 pm
Hi,
I purchased the package (start + shelf) and it is really neat, good job.
I have a question : what is the "Next style file browser" : I am trying to select the option "Use Next-style file browser" in the nextstart preferences, but it does not work, it always unslects itself.
I suppose it is different from what you get when you select "disk" in the start menu, right ?
Thanks in advance for your input,
Olivier
PostPosted: Thu Jan 19, 2006 6:07 pm
It always unselects itself?! Ooops... Maybe a bug? I'll have to look into it.
Anyway, that option is to select wether you want to use the Windows common controls to browse for files in NextSTART/WorkShelf or the special NeXT OS look-alike file browser. It is an internal choice, i.e.; only affects file browsing in NextSTART and WorkShelf, as in what pops up when you click the Browse button in the Sounds and Animations Preferences tab, for instance.
Users browsing this forum: Amazon [Bot], Google [Bot] and 181 guests
