Are you ever think to remove your Quick Launch from your Taskbar?
Frequently think.
50%
[ 1 ]
Ever think but not often.
0%
[ 0 ]
Never think.
50%
[ 1 ]
Total votes : 2
 Post subject: How to remove Quick Launch bar and all of Start Menu?
PostPosted: Wed Dec 30, 2009 2:04 pm
Location: 77/297 Moo 2, Tumbon Phanomsarakham Phanomsarakham 24120 Chachoengsao, Thailand
Can I remove my Quick Launch bar and Start Menu from the Taskbar?
There's anyway?
I think Quick Launch items are roughly, if it can be a shortcut like in Windows 7 I'd think it is beautiful. And I think I have my own Start Menu button and Windows 7 Start Menu from the program called ViStart.
I tried to change it by right click on Start Menu button and click on Associate to Windows Start Menu, but it don't work. Because I have my own Start Menu that isn't the default Windows Start Menu.
Can you help me?
Are you understand with my promiscuity speaking?
Sorry, if I make you muddled with my question because I'm Thai.
http://tinyurl.com/off99555
Make money from Internet with the easiest method! :)
PostPosted: Thu Dec 31, 2009 4:05 am
My apologies, not sure I understood correctly what you are asking... :cry:
Do you want to know how to disable the Quick Launch section in NextSTART's taskbar, how to display your ViStart custom Start Menu or both?
To disable the Quick Launch section on the NextSTART taskbar, open NextSTART Preferences, navigate to the 'Startbar Preferences' tab and then un-check 'Quick Launch' in the Sections area.
Not sure why you want to use a 3rd party custom Start Menu on an application already intended to customize your Start Menu - but you might try using NextSTART's hotspot capabilities to pull it off.
Thanks,
PostPosted: Thu Dec 31, 2009 9:47 am
You was understood in the correct case. I want to do both things. :P
But I don't know how to use hotspot capabilities?
Tell me a little please.
Thanks for all things you had gave to me.
Best regards.
Users browsing this forum: Amazon [Bot] and 217 guests
