 Post subject: Things I have found in the new releases....
PostPosted: Wed Jan 04, 2006 11:12 pm
Hi Jorge!
Hope the new year is going well, the newest releases are really nice. I have found two things...
I have a main "next start" menu that has been populated with lot of sub menus (internet, art, music.... etc) that were created by using the right click ->insert method (works well BTW). These sub menus are filled with application items via CTRL+drag from the "next start" programs menu (basically copying from one menu to another). There are two problem I have found with this new menu.
1: I cannot rearrange the items in the menu via shift+drag, I only get copies.
2: I cannot make a hotspot icon that will show this new menu. For example, creating an "Internet" menu via the above method gives me a menu that I cannot "show" via a hotspot icon.
I hope this is clear enough to understand. If not, I'll try again :D
-paul
PostPosted: Tue Jan 24, 2006 9:40 pm
Hi, and sorry for the very late reply.
You were right about not being able to re-arrange menu items. I fixed it already and the fix will be out in the next release (you do have the feature to automatically search for new updates enabled, don't you?).
As for menus created via 'New' or 'Insert' context menu entries, I just checked it and it is working properly. I think you might be confusing the LABEL in the parent menu (which originally shows as 'New Item') with the actual menu name. An entry in a menu pointing to a sub-menu can be labeled 'My Internet Programs' and point to a menu called 'Internet'. When making hotspots to these menus, you should look for the actual Menu Name (e.g. Internet), not for whatever you typed in the parent menu (e.g. My Internet Programs). Hope this makes sense...
PostPosted: Tue Jan 24, 2006 10:32 pm
Jorge,
Thanks for fixing the re-arranging issue. And yes, I was confusing the Label for the actual menu name.
Paul
Users browsing this forum: No registered users and 157 guests
