 Post subject: Can not get rightclick desktopmenu anymore
PostPosted: Sun Mar 14, 2010 9:47 am
When Workshelf is active I cannot get the desktop-menu anymore by rightclicking on the desktop.
Is that a bug or is there a solution?
I am only using Workshelf docks, not the shelf itself.
PostPosted: Sun Mar 14, 2010 9:56 am
What Windows version are you running? Do you have your desktop icons hidden?
PostPosted: Sun Mar 14, 2010 9:57 am
I am running Windows 7.
Only Recycle Bin on my desktop and a dock on the left side.
PostPosted: Sun Mar 14, 2010 10:00 am
Argh...ok...I think its solved....I had ...Icons hidden at startup
PostPosted: Sun Mar 14, 2010 10:26 am
Even with desktop icons hidden, right clicking on the desktop should have made the desktop menu popup... unless... you're still running Winstep Xtreme 9.5, aren't you?
PostPosted: Sun Mar 14, 2010 3:16 pm
Its version 10.1 that I run.
Which version do you recommend?
Users browsing this forum: Amazon [Bot], Google [Bot] and 179 guests
