 Post subject: Workshelf display bug
PostPosted: Wed Apr 07, 2004 7:26 pm
When I open preferences for Workshelf I see this:
I then have to click on the "UP" arrow in the bottom left corner to get the register box to appear. Doing this makes the Arrows disappear. Observe:
This causes the "Shelf Preferences" box to disappear at the top. I have to close the preferences and reopen it to get it back.
Is this supposed to function this way?
This is a very minor annoyance. Not critical, just wondering.
PostPosted: Wed Apr 07, 2004 7:28 pm
Tried it on a different machine and it does the same thing.
Both are WinXP machines.
PostPosted: Wed Apr 07, 2004 8:31 pm
No it's NOT supposed to do that. Just to clarify, clicking the down arrow didn't scroll down?
PostPosted: Thu Apr 08, 2004 1:00 pm
Yes, correct. After trying everything. Clicking up and down, clicking the scroll bar. Clicking the scroll bar and dragging it up and down.
Only the up arrow moves it for me.
PostPosted: Thu Apr 08, 2004 8:00 pm
Bug in v1.4. :(
Fixed. Watch out for a new release very soon now.
PostPosted: Thu Apr 08, 2004 8:22 pm
OK! Thanks!
Really just wanted to make sure I was not going insane (well at a quicker rate than I am already ;) ).
PostPosted: Wed Apr 14, 2004 5:35 pm
Just downloaded WS 1.5 and installed it.
When I go into WS preferences there is no UP/DOWN arrows to Registration button now. Nor can the scroll bar be moved. Is this because I have registered WS? Just checking.
PostPosted: Wed Apr 14, 2004 7:40 pm
Yes. When you register WorkShelf you no longer need to access the Registration tab in Preferences, therefore the scrollbar becomes disabled.
Users browsing this forum: Google [Bot] and 224 guests
