 Post subject: I want this theme for my dock
PostPosted: Thu Apr 08, 2010 9:42 pm
http://www.winstep.net/
i want the theme that is on the Winstep front page for my Nexus Dock, but where do i find it
PostPosted: Thu Apr 08, 2010 10:40 pm
I assume you are talking about the Leopard theme under the Nexus Dock section of the page.
Right-click the Nexus icon --> Appearance and Sounds --> NeXus Themes --> Leopard.
PostPosted: Thu Apr 08, 2010 11:30 pm
I have the latest version of Winstep and when i do that the theme is not there
PostPosted: Sat Apr 10, 2010 12:01 pm
Hmmmm, the only other thing I can tell you is to do the same thing as I instructed earlier but start with the Winstep icon.
Or, click on the little arrow on the Workshelf on the top left corner (that's where mine is since my Workshelf is at the top of the screen and not the bottom and I'm not sure if it changes if it's moved) and click the Themes tab.
If you don't see Leopard there, click the pull-down and click on NeXus and see if it's there.
Other than that, I can't help. Jorge "The Creator" will have to take the reins and give you the solution.
PostPosted: Sat Apr 10, 2010 4:07 pm
Only other thing I can think of is to make sure you are indeed looking under "Nexus Themes" and not "Themes" using Windy's first reply. It only shows under "Nexus Themes".
PostPosted: Sat Apr 10, 2010 5:11 pm
No, he's right, Winstep Xtreme doesn't have the Leopard theme, only Nexus does - and the Leopard theme hasn't been uploaded anywhere either.
I'll include Leopard with Xtreme on the next release, which should be soon now.
PostPosted: Sun Apr 11, 2010 2:20 am
Fantastic.As it looks great.Thanks.
When's the next update ?
 Post subject: Add Leopard theme to Shelf
PostPosted: Tue May 11, 2010 5:17 pm
Hey Jorge,
Can you add the "Leopard Theme" to the choices for Xtreme "Shelf" ? Its in the Nexus for the Dock (Looks Fantastic...) but not for Shelf...thanks...LandonC
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 239 guests
