 Post subject: Mozilla firefox and neXus
PostPosted: Sun Jul 11, 2010 12:35 am
Hi, I am using nexus v10.04.0904, basically everything works fine, except when I have firefox maximized and the dock set to the bottom, it will not pop up. It pops up for every other program I have tried except for firefox. I have all the settings set correctly for what should make it work, but its not. Any suggestions would be awesome.
 Post subject: Re: Mozilla firefox and neXus
PostPosted: Sun Jul 11, 2010 7:58 am
1. Is Firefox maximized or full screen? Two very different things.
2. Does the dock popup correctly when positioned at the top?
3. Is the dock docked or floating?
4. You're trying to activate it via a screen edge bump with your mouse pointer at the bottom, right?
5. Open Nexus Preferences -> Position & Behavior -> Advanced button. Give it an activation shortcut. Does that work?
Users browsing this forum: No registered users and 209 guests
