 Post subject: New user questions
PostPosted: Mon Jul 26, 2010 9:40 am
I am considering purchase of Winstep Extreme, and have a few questions which will help me decide if Winstep Extreme is right for me:
1.- Can your software be installed on more than one computer at a time (like Object Desktop by Stardock)? Yes, I am a Object Desktop subscriber.
My other computer is never used at the same time, so I hope this is not a problem.
2.- On the Nexus dock, Is it possible to get rid of the Nexus logo on the ends, I believe its a placeholder, there is also one where I created a sub-dock, but I want to create a totally unique look, and would like to remove or replace it with my own logo.
I know there will be more questions soon, but this is it for now.
Thanks,
Pink
 Post subject: Re: New user questions
PostPosted: Mon Jul 26, 2010 12:06 pm
Yes and Yes. :D
You can remove the Nexus control icon altogether from the dock, or you can simply make it display another icon. Just right click on it and either select 'Remove from Dock' or 'Dock Entry Properties'.
This said, it is always better to change it's icon and leave it on the dock, as it does have special functions.
PostPosted: Mon Jul 26, 2010 5:27 pm
Thank you for prompt reply, I just purchased it! :P
PostPosted: Mon Jul 26, 2010 5:29 pm
Thanks! :D
Users browsing this forum: No registered users and 199 guests
