 Post subject: Invisible Dock Items
PostPosted: Mon Oct 18, 2010 3:36 pm
Hi Folks,
Has anyone else noticed that when you add an item to a dock (unless you just choose "item" and then change the icon you might not actually get an icon to show it?
For example, if I right click the dock, select "Insert New Dock Item" =>"NextStart Hotspot" I have an empty space, and when I click it nothing happens.
Any ideas?
Fwiw - as a feature fo the next release - always force an icon so that *something* shows up.
John Strasser
Ph: 480-273-8798
Scottsdale, AZ USA
 Post subject: Re: Invisible Dock Items
PostPosted: Tue Oct 19, 2010 1:17 am
Err, you found a bug alright, but not the one you are thinking. Whatever 'Add NextSTART hotspot' is doing, it's not adding a NextSTART hotspot. :wink:
Right-click on the item and select Item Properties to see what I mean. Now use the combo box to change the item to a *real* NextSTART hotspot and you will see what it should look like.
PostPosted: Tue Oct 19, 2010 5:15 am
You're obviously more coordinated with a mouse than I am...
When I right click I get the general "dock properties" menu. No entry for "item properties" like I would get normally.
But at least I know now I'm not going crazy.
John
John Strasser
Ph: 480-273-8798
Scottsdale, AZ USA
Users browsing this forum: Amazon [Bot] and 215 guests
