 Post subject: Bonus pak of 1,000 dock tiles won`t start
PostPosted: Tue Dec 28, 2010 8:28 pm
Hi all, as newbie my first question. The Bonus pak of 1,000 dock tiles. It`s start with setup but can`t find the map :?:
At last I get on my screen "I didn`t work correct"
Have some one a answere
Hans.
 Post subject: Re: Bonus pak of 1,000 dock tiles won`t start
PostPosted: Sun Jan 02, 2011 8:54 pm
Hi!
If you've run the Setup file, as you seem to, then you can find your 1,000 bonus dock tiles by doing the following:
HOW TO USE:
After installing the tile pak, open the Dock Properties panel of any dock.
In the Dock Properties panel, go to the Themes tab and select 'Tiles' from the
combo box at the top left. You should now see a collection of tiles organized
by category.
This info is actually in the README file inside the bonus pak zip file, but, then again, who bothers reading README files these days? :wink:
Users browsing this forum: Amazon [Bot] and 209 guests
