 Post subject: directx&shelf
PostPosted: Tue Dec 28, 2010 1:45 pm
Hi
I use a floating shelf at bottom.
After playing some games which use directx drivers, after the ending my
shelf is at the upper side of screen, and I can not move it to bottom.
I must logoff and login again, then the shelf is at bottom again.
 Post subject: Re: directx&shelf
PostPosted: Sun Jan 02, 2011 8:28 pm
Are you running the latest version of Winstep Xtreme or Nexus Ultimate?
Do those games change the screen resolution?
You can also try opening Preferences and pressing OK to refresh the Shelf, instead of logging off.
PostPosted: Tue Jan 04, 2011 3:46 pm
Yes
Yes
Where can I find in Preferences the refresh option?
Users browsing this forum: Amazon [Bot] and 218 guests
