 Post subject: reinstall
PostPosted: Sun Feb 13, 2011 7:02 am
I had to reinstall winstep. I still have the key file and I have not tried to open it, but I don't remember how to activate it. can someone help me.
Vernon Scally
vscally@antelecom.net
 Post subject: Re: reinstall
PostPosted: Sun Feb 13, 2011 7:35 am
What's the extension of the key file? If .xtreme, just double click it. If .key, stick it into the Licenses folder. :wink:
PostPosted: Sun Feb 13, 2011 9:52 pm
It is wsxkey. But there isn't a license folder.
PostPosted: Sun Feb 13, 2011 10:04 pm
just double click on file *.wsxkey and reload winstep program.
this is a licence patch, after double click on file *.wsxkey you see one file with ext *.key on this patch so you registered
C:\Documents and Settings\All Users\Documents\Winstep\Licenses
PostPosted: Mon Feb 14, 2011 5:42 am
Thank you! Thank you
Users browsing this forum: Google [Bot] and 197 guests
