 Post subject: NextSTART cannot locate WorkShelf
PostPosted: Wed Mar 30, 2011 1:18 pm
I keep getting this message after I start my computer and one of my Hotspot menus pops up and stays on the screen until I right-click to remove it.
I uninstalled the older version and reinstalled the new one. I used the saved settings and made manual changes also so I may have screwed something up in the process.
 Post subject: Re: NextSTART cannot locate WorkShelf
PostPosted: Wed Mar 30, 2011 3:18 pm
Check all your hotspots to see if one is set to 'Activate On Startup'.
PostPosted: Wed Mar 30, 2011 4:12 pm
Thanks. It no longer shows the error message. While tinkering around with Hotspots which I mentioned in my other thread, I changed the settings.
FYI, per your instructions to check the settings, I decided to at first change only the setting (unchecked Perform this action when NextSTART runs) for the one Hotspot that was displayed at startup. The others weren't displaying so I didn't change them.
I restarted and the Hotspot no longer displayed but I still got the error message.
I changed all but the Desktop Modules Hotspot settings since those are displayed once Winstep starts. I restarted, but still got the error message.
I then changed the Desktop Modules settings so now none of the Hotspots are set to activate on startup of NextSTART. I restarted and as mentioned above, all is well.
Users browsing this forum: Amazon [Bot] and 192 guests
