 Post subject: drag and drop out of bar to remove link of program
PostPosted: Fri Apr 01, 2011 6:13 pm
is possible to drag and drop out of bar to remove link of program? thanks!
 Post subject: Re: drag and drop out of bar to remove link of program
PostPosted: Fri Apr 01, 2011 6:28 pm
No, because Nexus offers true drag & drop (drag a shortcut from the dock into the Desktop and you create a shortcut in the Desktop to that item).
You can do the next best thing, though: drag the dock item into the Recycle Bin module *on the dock* (NOT the Windows recycle bin, as that will not recognize Winstep items) and drop it there.
PostPosted: Sat Apr 02, 2011 11:39 pm
thanks for reply...
i saw your sign, i got curious, are you from brazil?
PostPosted: Sat Apr 02, 2011 11:47 pm
Portugal.
Users browsing this forum: Amazon [Bot], Google [Bot] and 233 guests
