 Post subject: Winstep Color Chart
PostPosted: Sat Apr 23, 2011 5:07 pm
jorge,
any chance you can post the numbers for various colors for winstep. the reason i ask is that your color plate doesn't match up with paint.net or photoshop. i was running a custom theme by nofx1994 and got the background for all the parts of winstep to match so closely that it didn't matter about the slight difference, however the fonts were a different story. nofx1994 gave me the numbers he used in photoshop for his themes fonts, but when i used those numbers in winstep my fonts for winstep would of been a pink instead of a almost gold color that i needed to match his theme. i thought maybe i was having problems with my color plate so i asked a couple of others who had recently purchased winstep to check, and they got the same thing.
 Post subject: Re: Winstep Color Chart
PostPosted: Sat Apr 30, 2011 2:11 pm
BUMP
PostPosted: Sat Apr 30, 2011 7:47 pm
Color format is BGR, or B*65536 + G*256 + R. I didn't check, but it's probably backwards from Photoshop.
You'll understand better if you convert the number to hexadecimal. For instance, the color 16759535 in hexadecimal is FFBAEF, which means 255(FF) Blue, 186(BA) Green and 239(EF) Red.
You asked for it. :P
PostPosted: Sat Apr 30, 2011 8:36 pm
cool, now i should be able to get a pretty close match to what i want. adjusting the color from that point should be far easier now. thanks
