 Post subject: Nextstart menu folder spacing
PostPosted: Wed May 11, 2011 2:22 pm
Hello! Looking at my screen capture, is there any way to increase the distance between the folders in the list? I have looked and looked in the preferences. I'm using version 11.2!
 Post subject: Re: Nextstart menu folder spacing
PostPosted: Wed May 11, 2011 3:26 pm
Unfortunately you will have to wait until the Winstep Theme Builder is released to change skinning settings like that. Unless you want to delve into text file theme configurations, but that's not recommended.
PostPosted: Wed May 11, 2011 3:28 pm
Ok, thanks! I will live with it for now.
Users browsing this forum: Amazon [Bot] and 226 guests
