 Post subject: System Tray effects
PostPosted: Fri Jul 08, 2011 3:25 pm
Does anyone know of a way to have effects (bounce etc.) on the Nexus dock and have the tray icons NOT have any effects?
 Post subject: Re: System Tray effects
PostPosted: Fri Jul 08, 2011 3:28 pm
Can't be done on the free version, sorry.
With Nexus Ultimate you can put the systray on a dedicated dock and then turn mouse over effects off for that dock.
PostPosted: Fri Jul 08, 2011 3:46 pm
Jorge:
Que resposta rapida homen! Muito obrigado. Que programa otimo tambem. Eu vou comprar o xtreme.
PostPosted: Fri Jul 08, 2011 3:57 pm
Boa! És Português? Ou isso foi Google translate? :wink: :D
PostPosted: Fri Jul 08, 2011 4:08 pm
Sou americano/uruguayo e morei no Brazil 5 anos em Brasilia e Campinas/Sao Paulo. Agora em EEUU no estado de Illinois. E verdade, o seu programa e uma maravilha! Obrigado - Daniel
PostPosted: Fri Jul 08, 2011 4:11 pm
Obrigado, Daniel. :D
Users browsing this forum: No registered users and 218 guests
