 Post subject: Performance issue caused by Anti-virus/Anti-mal... Revisited
PostPosted: Mon Aug 08, 2011 11:44 pm
[Original subject truncated due to length limitation]
In the original topic (see Announcements) Jorge wrote:
Update settings won't even affect WorkShelf's Internet usage, since all update checks are made via the external Winstep Update Manager (WsUpdate.exe) application. WorkShelf will access the Internet to retrieve weather information, synchronize the time with Internet time servers, etc...
Anyway, if you want to discuss this further please start a different thread. :D
That may be so but there appears to be a correlation between Workshelf consuming an unusual percentage of processor power and the update checks.
In the last week or so I have been running Winstep Xtreme on a new Win7 64bit system; previously I had run Winstep under XP Pro 32 bit.
Under the new system Workshelf has been exhibiting strange behavior of consuming just under 25% CPU (measured using SysInternals Process Explorer) for extended periods. It would then revert back to normal for no obvious reason. If it was running normally, merely opening the preferences window would push the CPU up to 25% again although going to the Advance Tab, selecting "Performance Settings" and holding that window open would drop the CPU back to normal until you closed that window when it was back to 25%.
One other apparently correlating event was that selecting "Check for Updates" in the Advanced sections of either NextStart or Workshelf gave the same result - Check... Failed, Connection to Update Server Failed. I have not as yet been able to determine the cause of the failure. I have since altered the Update configuration to just one box ticked; Prompt me before checking for new updates.
Yesterday evening in ESET NOD32 AV I excluded the Workshelf executable from scanning and so far that appears to have resolved the issue of the CPU usage BUT why? I have been using ESET NOD32 for many years and this is the first time I have needed to exclude any file from scanning. However, the majority of that time has been under XP Pro 32 bit of course.
Back to the Update correlation. Check for Updates still fails for the same reason but while WsUpdate is running it consumes the identical ~25% CPU as Workshelf used to. Coincidence? Maybe. I have now excluded WsUpdate for ESET's scanning but it still fails to connect to the server.
What protocol is WsUpdate using and what server is it trying to connect to?
Regards to All,
Chris
 Post subject: Re: Performance issue caused by Anti-virus/Anti-mal... Revis
PostPosted: Tue Aug 09, 2011 8:04 am
Hi Chris!
Ok, you asked for it so I am going to get technical on you! :wink:
The Winstep Update Manager contacts the Winstep.net server via port 80 using the HTTP protocol. It downloads a simple text file (just like your browser would if you typed http://www.winstep.net/<xxxx>.txt in the address bar) that holds information about the latest versions, which is then used to compare with the versions installed on your computer... as simple as that.
The 'apparent' (I'll explain why I say apparent below) large CPU utilization problem might be caused by one of two things: a DNS (Domain Name Server) resolution issue or a 3rd party DLL injected into the Winstep process (this is what AV software usually does).
When Winstep applications communicate via the web, Winsock gets passed a domain name - e.g.; http://www.winstep.net - which must first be resolved into an IP address via WSAAsyncGetHostByName. Unlike the actual 'get the data' phase that comes next, and which is performed asynchronously, the DNS lookup actually loops the code with a DoEvents instruction in the middle until the domain name has been resolved into an IP address.
Now, what does DoEvents do? DoEvents passes control to the operating system. Control is returned after the operating system has finished processing the events in its queue.
The loop waits for a specific condition (in this case either a timeout or an IP address), and, if that condition has not been met yet, it uses DoEvents to suspends the current thread and pass execution back to the Windows message pump. In order words, with DoEvents the application 'surrenders' its processing time to Windows so that other parts of the application continue to be responsive (without DoEvents, the application would simply 'block' until the condition was met and the loop exited, with DoEvents it remains responsive to mouse events, etc...). The Windows message pump processes any pending events and then returns execution to the instruction after 'DoEvents'.
If the message queue is empty or nearly empty (as it will be most of the time because all this happens very rapidly), the tighter (and faster) the DoEvents loop will be. The spike in CPU activity you see is NOT because the application is busy doing something processor intensive, but because the Windows message pump is being executed more times than normal. In other words, it's not the application itself using all that CPU, but the Windows message pump. However, because the purpose of the Windows message pump is to execute events for *all* running applications, you are not taking processing power away from the rest of the system - you are doing the exact opposite, in fact.
This would be pretty evident when using DoEvents in a single core processor: in that case the application using DoEvents would appear to be using 100% of the CPU, but run another processor intensive application at the same time and you will see that it runs at full speed instead of really slow as it would happen if the DoEvents application was *actually* doing something processor intensive.
So, getting back to our DNS resolution routine, if there is a problem converting that domain name into an IP address, then the loop will run until a timeout condition occurs (usually 30 seconds). If DNS resolution fails for some external reason (DNS server is down, or *something* in your system is preventing it?) then the application is unable to get the corresponding IP address and, without it, communication cannot proceed.
I suspect this is what is happening to you, although I have no idea why.
So why use DoEvents resolving domain names when the remain data exchange is truly asynchronous (i.e.; packets are sent to the application as they are received instead of the application polling for them)? Because the original Winsock library used by Winstep did *everything* in a synchronous way and was modified so that the important (and much more time consuming) 'get the data' part was done asynchronously. I suppose I could have modified the DNS resolution part so it too was truly asynchronous, but it would be a lot of work for very little return since domain names are *usually* resolved in milliseconds.
As for 3rd party DLLs injected into your process, the reason why they might make your application run 'slow' or use a lot of CPU is because, even though the DLL does not belong to your application, it is running in the same process space. Anything that DLL does will be attributed to YOUR process, NOT to the process that injected that DLL in the first place.
For instance, if an AV injects a DLL into your process that scans a file every time your application opens one, the time spent by that DLL scanning the file will appear under your process name in Task Manager (i.e.; that time will be added to the 'normal' processing time used by your application to perform its own tasks). Hardly fair but this is how it works.
P.S. I run Eset Smart Security here (so NOD32 is my AV too) and I have no problems with it whatsoever.
PostPosted: Tue Aug 09, 2011 3:25 pm
1. First off I checked the http://www.winstep.net domain name resolution via DNSstuff to be sure I knew the correct IP address.
DNS Lookup: http://www.winstep.net A record
http://www.dnsstuff.com/tools/lookup?na ... 1f39e3c01d
or
http://preview.tinyurl.com/3sp6oov
DNS Traversal for http://www.winstep.net.
http://www.dnsstuff.com/tools/traversal ... net&type=A
or
http://preview.tinyurl.com/3d4jaee
ISP DNS Lookup of http://www.winstep.net A record
http://www.dnsstuff.com/tools/ispdns?na ... 1101c35012
or
http://preview.tinyurl.com/3gqt6gd
[The above links are valid for 7 days from now.]
2. I use OpenDNS so I checked the OpenDNS dashboard and was surprised to find recent activity was zero. I next checked the router and discovered it was set to auto for DNS server which meant it was using my ISP's DNS servers. I vaguely recall having problems with DHCP on previous machine/OS configuration and must have configured the OpenDNS server addresses in the machines network config. As well as reconfiguring the router I have also added the OpenDNS server addresses to this machines network config so as to remove DHCP from the equation.
3. Following the above, manual update checks via NextSTART continue to fail. OpenDNS reports one successful resolution of http://www.winstep.net which for the moment I assume was triggered by an manual UPDATE check I have only accessed forums.winstep.net this morning (different IP address as it happens). This suggests that WsUpdate does start the process but then something breaks. The ESET NOD32 Win7/64 setup appears slightly different to that of WinXP/32 that I have been used to so I have also just excluded WsUpdate from HTTP protocol scanning but the manual update check still fails.
That's the state of play at the moment. I have to go and do other work now but will do some more debugging later today.
Regards to All,
Chris
Users browsing this forum: Amazon [Bot], Majestic-12 [Bot] and 219 guests
