 Post subject: 6 trips to the forum and Installed
PostPosted: Fri Oct 21, 2011 5:06 am
I would have preferred a manual but... After going through the available screens for the settings I have a question.
How do you get this thing out of second gear. Bad joke from the day.
How do you hook up the list of start programs to the task bar on the left side. I'm looking for the action that was similar to using Windows 7.
Also in the NextSTART preferences "Menus" you make reference to the "Menu TitleBar". What exactly would that be?
Bob
 Post subject: Re: 6 trips to the forum and Installed
PostPosted: Fri Oct 21, 2011 6:35 pm
Not sure I understand, can you explain better, please? :D
Check THIS 'Anatomy of a menu' section on the old NextSTART User Guide for an explanation.
Please note that *some* themes do not provide a full menu title bar.
