 Post subject: From Winstep Xtreme to Nexus Ultimate: Preserving Settings
PostPosted: Tue Sep 20, 2011 10:58 pm
I just started playing with the free versions of Nexus Ultimate 11.6 and then Winstep Xtreme 11.6 yesterday. After a while with those apps, it was clear to me that Nexus Ultimate would be ample to suit my needs since I mainly wanted the sub-dock functionality. However, the version that I have customized to my liking and which is still on my system now is Winstep Xtreme (well, the dock is there, but from the Xtreme installation and not from a stand-alone Nexus Ultimate installation).
So, as I am getting ready to purchase Nexus Ultimate, my questions is this:
Is there a way to PRESERVE ALL THE CUSTOMIZATIONS I have done to the dock and sub-docks from the Winstep Xtreme installation so that I can import them when I install the purchased version of Nexus Ultimate?
P.S. I noticed the Backup button functionality in the Winstep Xtreme Preferences dialog, but I am not sure how that would work with a Nexus Ultimate stand-alone installation.
 Post subject: Re: From Winstep Xtreme to Nexus Ultimate: Preserving Settin
PostPosted: Wed Sep 21, 2011 11:15 am
I've never tried this but I think that backups should contain separated settings for any program, so i think that when you're going to use the Xtreme backup on Nexus Ultimate, it'll just read the settings for Nexus Ultimate, ignoring the other existing settings.
PostPosted: Wed Sep 21, 2011 5:13 pm
No, sorry, they are stored in separate parts of the Registry.
Just to a backup of Nexus Ultimate settings into the Desktop, then import (restore) those settings into WorkShelf.
PostPosted: Wed Sep 21, 2011 5:21 pm
Aren't you supposed to be in some subtropical island smoking cigars?
PostPosted: Wed Sep 21, 2011 5:43 pm
Let's make I understand you correctly:
- I should be able to install the free version of Nexus Ultimate ON TOP of my currently customized version of Winstep Xtreme
- then go to Nexus Ultimate and create a backup to desktop
- then uninstall everything
- then install a purchased version of Nexus Ultimate
- then import the backup I created earlier?
To clarify, I don't want to keep Xtreme/WorkShelf, I want to keep the settings of the dock/sub-docks I made in my Xtreme installation and carry them over when I install my purchased version of Nexus Ultimate. Makes sense?
SOLVED: Just tested it and it worked flawlessly. :D
PostPosted: Fri Sep 23, 2011 7:30 pm
I am. :P
PostPosted: Fri Sep 23, 2011 11:18 pm
I am. :P
In that case, get smokin' and stop postin'...
...seems like you post more now, than when you were home. :D
PostPosted: Mon Oct 24, 2011 11:51 am
May I jump in here:
How do I save the Shelf setting from Ultimate - I do not see the relevant menu items in the left Mini-tab context menu:
According to Help I'm missing some items here(which may have been moved elsewhere).
The other left Minit-tab does not contain the needed items either:
Please give me a hint.
PostPosted: Mon Oct 24, 2011 12:04 pm
Oh sorry, for bothering You all,
I have found in the FAQ: Preferences > Advanced > Backup
PostPosted: Mon Oct 24, 2011 5:33 pm
No bother, but yes, the FAQ does have lots of interesting and useful tidbits of information. :wink:
Users browsing this forum: Amazon [Bot] and 204 guests
