 Post subject: Security flagged NextSTART
PostPosted: Wed Dec 07, 2011 11:56 am
Jorge, I sent you a couple of important PM's.
 Post subject: Re: Security flagged NextSTART
PostPosted: Thu Dec 08, 2011 2:14 pm
Oops, Jorge I just realized that I replied to myself yesterday so only one PM was sent to you. Please check out the PM as it has pertinent private info from my PC.
I want to make sure that this is a false/positive and I didn't pick up some sort of malware and you can contact them to remedy the notification if in fact I didn't pick up malware.
Of course, I received the message again when I started my PC just now.
Here is the pic I meant to send for the reply.
PostPosted: Thu Dec 08, 2011 7:46 pm
False positive, of course.
When in doubt, submit the executable to http://www.virustotal.com to get it scanned by over 40 different AV engines.
PostPosted: Fri Dec 09, 2011 1:19 am
For some reason the link you posted won't load. I tried different browsers with no luck. I'm not sure if it's something on my end causing it. I'll deal with it later to try to make it work.
Jorge, I'm not sure, but I may have found out the reason I received the false/positive message and will send it to you.
Please check your PM. This is very important.
Users browsing this forum: Amazon [Bot], Google [Bot], Majestic-12 [Bot] and 109 guests
