 Post subject: Crash in Xtreme After Using New Dock Item
PostPosted: Mon Jan 16, 2012 1:55 pm
Hi Jorge, little problem. The other day I was setting up my friend's Xtreme (just like my configuration) that was just purchased by them, and instead of dragging a folder to the Dock like I normally do, I decided to instead:
1. Right-click on a Dock and selected Insert New Dock Item --> Item
2. Under Item Type: I selected Folder, added file name, and OK.
After doing so, the two Desktop Modules that were set to the K-TEK-4D theme turned black and Xtreme crashed and locked-up.
See here. http://www.youtube.com/watch?v=laNfsIeJ ... r_embedded It's the two Desktop Modules (Ram and CPU) near the top left of center.
I logged-off and then on again (a quicker way instead of restarting) and any minor use of Xtreme, even right-clicking on a Dock would cause the same thing to happen again.
I tried using the Restore settings but that wouldn't work. BTW, anytime in the past when I've tried using the Restore settings they never quite work correctly. I backup both the Workshelf and NextSTART.
Ultimately, I had to use System Restore on the PC to remedy the problem.
P.S. The laptop was brand new (Windows 7 of course, i7 processor, Blu-ray etc.) and except for the security programs, Xtreme was the first program I installed on it.
Users browsing this forum: Amazon [Bot], Google [Bot] and 132 guests
