 Post subject: Full Screen Width
PostPosted: Thu Feb 09, 2012 11:46 pm
Jorge - Testing out using Workshelf instead of Nextstart as a windows taskbar replacement.
Is there a way to for the width of the workshelf to full screen?
 Post subject: Re: Full Screen Width
PostPosted: Fri Feb 10, 2012 12:15 am
Sure. Is that a single or multiple monitor system we are talking about?
For a single monitor screen, assuming the Shelf is docked, it should be a simple question of opening the Shelf Properties dialog, go to the Position tab and enabling 'Span the full screen width when docked'.
If you want the Shelf to span all your monitors on a multi-monitor environment (assuming all monitors have the same resolution) you can also enable 'Extend shelf over all monitors when docked'.
If the Shelf is not docked, you can manually re-size it horizontally by dragging the Shelf edges.
PostPosted: Fri Feb 10, 2012 12:55 am
Got my terms mixed up. This is referring to a Dock not a Shelf.
PostPosted: Fri Feb 10, 2012 1:20 am
Ah, no, the dock will only be as wide as strictly necessary, sorry.
This said, I have a pretty good idea of what you want, saw an option to do that (extend the dock background) in one of the Linux docks.
Users browsing this forum: Amazon [Bot], Google [Bot] and 118 guests
