 Post subject: Dock Icons/Task Icons
PostPosted: Sat Feb 11, 2012 1:51 pm
Hi,
I love the software! I upgraded to the ultimate, but I am still having a problem with the way the dock works.
Is there anyway to set it so that the icons in the dock when clicked will open up the already open windows?
Example - I have chrome open and the dock is showing an arrow under the icon letting me know chrome is open, and I see the chrome window as a task window on the right hand side of the dock. So lets say I go to notepad to type something, then I go down to the dock to get back to chrome and click on the dock icon for chrome (not the task icon window), it will open up a whole new chrome window.
So my question is, is there a way to make it open the already open occurrence of chrome instead a new one?
 Post subject: Re: Dock Icons/Task Icons
PostPosted: Sun Feb 12, 2012 2:46 am
Open Dock Properties for one of the docks, go to the Behavior tab, enable 'Do no launch multiple sessions'.
This setting is global, so it will affect all docks and the Shelf.
PostPosted: Sun Feb 12, 2012 2:48 am
YES! Thank you! That was driving me nuts :)
Users browsing this forum: Amazon [Bot], Google [Bot], Majestic-12 [Bot] and 111 guests
