 Post subject: Theme colorization not working for you in v12.2?
PostPosted: Sat Mar 24, 2012 12:58 pm
In our haste to bring the incredible new features in v12.2 to Winstep users, a small last minute change made to the code was not properly tested and ended up breaking the theme colorization feature.
The issue was detected and fixed in less than 24 hours, but, given the quick verification cycle of the Winstep Update Manager, by the time the new version was put online most of you had already updated to the release with the problem.
In order not to force another update cycle on users who are not affected by this issue - or who don't use the colorization settings - we will be treating this as a silent update.
The versions that fix the the colorization issue are:
Nexus: v12.2 build 991
Nexus Ultimate: v12.2 build 1002
Winstep Xtreme/WorkShelf: v12.2 build 1034
You can check which version/build you are currently running by opening the Preferences screen of Nexus, Nexus Ultimate or WorkShelf and clicking the version number at the top right corner of the About tab.
If the build number is equal or greater than the one listed above for the application you have, then you are already running the version that fixes this problem. If it is less, you can download the latest update by choosing the option that applies to you below:
Click here to download the update for the free version of Nexus.
Click here to download the update for Nexus Ultimate.
Click here to download the update for Winstep Xtreme.
WARNING: The above files are updates with essential files only, and require a previous full installation of Nexus v12.2, Nexus Ultimate v12.2 or Winstep Xtreme v12.2. Remember to exit all running Winstep applications before running Setup.
Our sincere apologies for any inconvenience this might have caused you.
 Post subject: Re: Theme colorization not working for you in v12.2?
PostPosted: Sun Mar 25, 2012 1:03 am
hello I have just this problem since I upgraded to version 12.2 does not work the color theme for the dock.
You know when it will be restored?
Thank you.
Winstep Nexus 12.2.0991
PostPosted: Sun Mar 25, 2012 2:16 am
Did you read the post above yours?
PostPosted: Sun Mar 25, 2012 10:06 am
sorry but I do not understand English well.
Can you tell me what should I do?
Thank you.
PostPosted: Sun Mar 25, 2012 10:11 am
Google translate always saves my bacon on those situations.
Anyway, to cut it short:
PostPosted: Sun Mar 25, 2012 10:24 am
I thank you, while you were writing the post I realized that the version I had was different than that posted by you, mine was the last 12.2.0990 instead.
Thanks, a really great dock! :)
Users browsing this forum: Amazon [Bot], Google [Bot] and 136 guests
