 Post subject: Hot Spot Opening Location
PostPosted: Sat Dec 03, 2011 9:31 pm
I use a hot spot – the bump the left side of the screen – to open the Start Menu (Run an internal command >Start Menu). If I bump the left side of the screen at approximately the center the Start Menu does not completely display with the top lost beyond the top of the screen. Touching anywhere but the approximate center of the left side the Start Menu moves itself to display properly. Any idea what I’m doing wrong?
 Post subject: Re: Hot Spot Opening Location
PostPosted: Mon Dec 05, 2011 4:46 pm
Looks like this:
PostPosted: Mon Dec 05, 2011 5:57 pm
Thanks for the screenshot, that helps.
I'm currently in Italy, but I'll look at it when I come back.
PostPosted: Mon Dec 05, 2011 6:52 pm
Thanks - always liked Italy
AM
PostPosted: Sun Dec 11, 2011 5:54 pm
Any ideas - other than not bumping the edge in the center?
AM
PostPosted: Sun Dec 18, 2011 2:37 pm
Bump
PostPosted: Sun Dec 18, 2011 3:58 pm
Bump to you too. :P
I'll fix it for next release.
PostPosted: Sun Dec 18, 2011 11:20 pm
Sounds good. Thanks
PostPosted: Mon Dec 19, 2011 4:02 am
One thing though: you won't be having this problem when you upgrade from Vista to Windows 7...
That's because in 7 Microsoft made something to the Windows Start Menu that causes it to become visually corrupted on mouse over if it appears anywhere else on the screen other than where it was supposed to appear at.
Almost like they did it on purpose.
In the end both Jeff (ObjectDock) and I were forced to make the Windows Start Menu appear at a fixed position when running Windows 7, instead of under the mouse pointer.
PostPosted: Thu Mar 29, 2012 12:41 pm
Jorge -
I'm upto date with 12.02.1037 - and still have the problem sited. Any suggestions for a fix?
AM
PostPosted: Thu Mar 29, 2012 1:42 pm
Ooops. I think I forgot about this. :oops:
PostPosted: Thu Mar 29, 2012 1:54 pm
Oh well - I can deal with it.
AM
PostPosted: Thu Mar 29, 2012 4:11 pm
Sorry... :(
I'll try to fix it for next release. I just had too much on my plate at the time.
PostPosted: Thu Mar 29, 2012 4:26 pm
Yea, I see you were quite busy and this is minor,so no worries.
Thanks for your help.
AM
Users browsing this forum: No registered users and 244 guests
