 Post subject: nextstart and previous size windows
PostPosted: Sun Apr 22, 2012 4:30 pm
I tried the trial version of Winstep Xtreme, and I liked it, but something that I liked. In windows 7 when hit with a window on the left or right edges, I is maximized at one of those sides. If I minimize the window to open the application bar (NextSTART)and return to open, the window does not maintain its previous size. Is there any solution for this?
Thanks in advance and best regards.
 Post subject: Re: nextstart and previous size windows
PostPosted: Sun Apr 22, 2012 5:47 pm
Not currently, unfortunately, but I'll look into this to see what I can do.
PostPosted: Wed May 23, 2012 3:26 pm
Is there anything new or alternative on this issue? I consider it important for the continued operation of windows, because you have to constantly be changing the size. Do you expect changes on this in future versions? Thanks in advance and best regards.
Users browsing this forum: No registered users and 189 guests
