 Post subject: Roll over info
PostPosted: Mon Feb 11, 2013 5:25 pm
Thanks for a great piece of software which really increases my productivity. I was wondering if there was a way to disable the roll over info shown on the picture below, thank you.
 Post subject: Re: Roll over info
PostPosted: Tue Feb 12, 2013 12:28 am
In Workshelf Preferences, select the tab General, click More Options and under Behavior select when or which information should be shown in a balloon.
PostPosted: Tue Feb 12, 2013 4:07 am
I think that's a Dock and not WorkShelf. It's just that the OP has it set at the top of the screen instead of the bottom.
For a Dock:
1. Right-click on the Nexus icon > Preferences > General tab > More Options > Under the Behavior heading, click the pull-down and select the one you want > Ok > Apply, Ok.
PostPosted: Tue Feb 12, 2013 3:02 pm
Perfect, just what I needed :)
Users browsing this forum: No registered users and 201 guests
