 Post subject: Windows XP Start up
PostPosted: Fri Jul 27, 2012 5:55 pm
Hi,
System is showing the following:
Yes HKCU:Run NextStart D:\Program Files\Winstep\nextstart.exe autostart
Yes HKCU:Run WorkShelf D:\Program Files\Winstep\workshelf.exe autostart
Yes HKLM:Run NextSTART
Yes HKLM:Run Workshelf
Why the double entry?
Thanks.
Mist
 Post subject: Re: Windows XP Start up
PostPosted: Mon Aug 13, 2012 6:05 am
Maybe you installed an older version of the software? Anyway, if the HKLM entries are blank (as they seem to be), don't worry about it.
Users browsing this forum: Google [Bot] and 195 guests
