 Post subject: Purchasing just NextSTART but installed Full winstep trial
PostPosted: Wed Jun 02, 2004 2:01 pm
I installed the full version of Winstep, and after playing with both nextSTART and the Workshelf, I think I really only need nextSTART. (Reason being, that with my own custom menu that I have pop up from bumping the left edge, I have quick access to all the apps I need in there, broken down within submenus. Seems just as fast getting to them that way as it does using WorkShelf). The question I have is that I'd like to purchase nextSTART but not sure what I should do about my current full install. Should I uninstall and then install just nextSTART? Thanks for any help.
PostPosted: Wed Jun 02, 2004 2:10 pm
Nah, unless you are really, really, worried about hard disk space. Just register NextSTART and don't run WorkShelf once the trial period is over.
Users browsing this forum: Amazon [Bot], Google [Bot] and 177 guests
