 Post subject: Network Drives
PostPosted: Wed Aug 02, 2006 10:48 pm
Jorge,
I have a NS menu called "drives". In this menu are the usual suspects, C:\ D:\ etc... I also have a network drive that I use at work. Sometimes, if I am connected to another network (not the work Lan), and I go to open the "drives" menu, it will take 10-15 seconds to open, presumably it is querying the network drive. Would it be possible to make it so that opening the "drives " menu does not initiate a network query? I would think that the only time NS should try to connect would be the actual drive button was pressed.
Just a thought.
Paul
PostPosted: Thu Aug 03, 2006 8:17 am
Problem is that the shell itself probably queries the network drive to get info like which icon to use, etc...
PostPosted: Thu Aug 03, 2006 3:38 pm
Well then, I guess you'l have to make WSX a full blown shell!
I figured it was an explorer thing....
Users browsing this forum: Amazon [Bot], Google [Bot] and 162 guests
