 Post subject: Screen capture
PostPosted: Thu Jun 10, 2004 3:30 pm
I use the screen capture program from AnalogX called "capture", but since installing Winstep I find that it no longer captures just the "active" window, but the entire desktop. Is there some setting I missed when I installed Winstep? Maybe someone can recommend an alternative way to capture just the active window?
-jeff
PostPosted: Thu Jun 10, 2004 3:35 pm
How embarrasing :(
Alright, I admit I'm an idiot at times. I forgot completely about Alt-Printscreen which works fine. My problem with capture must be related to how it interacts with the window system. As long as I can Alt-Printscreen I'm a happy camper :D
FWIW, Winstep is arguably the best thing I have ever installed on my computer. As an old-time NeXT user, I was always looking for the same look-n-feel for my Windows systems. I've finally found one that does exactly what I needed. Thanks folks!
-jeff
Users browsing this forum: Amazon [Bot], Google [Bot] and 158 guests
