 Post subject: Winstep Xtreme v6.11 Final Released!
PostPosted: Sat Nov 25, 2006 9:11 pm
Winstep is proud to announce Winstep Xtreme v6.11 Final.
Screenshots:
Image Image Image
After many months of extensive development and beta testing, Winstep Xtreme Final (including NextSTART, WorkShelf, NeXuS and FontBrowser) is here at last!
Click HERE for exhaustive information on this awesome release.
PostPosted: Mon Nov 27, 2006 3:47 am
is there a way to use nexus only? and not the workshelf
PostPosted: Mon Nov 27, 2006 5:24 am
No but check out this thread about the same topic:
http://forums.winstep.net/phpBB2/viewtopic.php?t=539
Marc
== ANIME SENSHI ==
Marc D. Williams
PostPosted: Mon Nov 27, 2006 12:42 pm
Marc, he won't be able to read that thread since it's in the Beta Discussion Forum, which is accessible to registered users only.
It's not possible to run NeXuS without WorkShelf (so much depends on the shelf that it is not possible to have only the docks running) , although a switch will be provided in the next update to hide it.
What you can do is set the shelf to 'collapse to frame', 'start collapsed' and disable the edge bump. And if you're bothered by even the tiny bit of WorkShelf's that's still visible, set the workshelf transparency when collapsed to 100%.
PostPosted: Wed Nov 29, 2006 11:16 am
Ach! I forgot about that.
First post in months and I goof. :oops:
Users browsing this forum: Amazon [Bot], Majestic-12 [Bot] and 206 guests
