 Post subject: nextstart issues??
PostPosted: Fri Mar 16, 2007 1:06 am
Hi there..
i have a tiny issue with settings?? i don't know how to stop the nextstart to not load??
i wanna keep the vista homepremium theme (aero) as is but have all da othertoys/options running??
i have created my own theme and saved it.. but after a restart i get the nextstart theme/toolbar again.. i have even deleted all the themes out of program just leaving my custom theme.. but still wont load up my saved theme properly..
my custom theme is basicilly just the aero low res theme which i've deleted the nexus dock and exited the nextstart toolbar(so it goes back to the vista aero skin..)
Can/does any body have any suggestions about this??
I would be very greatfull for any suggestions...
regards justin... :lol:
PostPosted: Fri Mar 16, 2007 3:41 am
Hi again..
thort i'd let ya know that i figured out how to fix this problem if any body else run's into this problem too with vista home premium..
wot ya need to do is go into ya start menu and open windows defender..
then click on the tools..
then click on the software explorer..
then check through the start up programs..
find winstep programs and then disable the programs you don't want to start up.. IE: nextstart..
thats it.. all fixed..
regards justin.. :lol:
 Post subject: Stopping NextStart or WorkShelf from loading at startup
PostPosted: Fri Mar 16, 2007 9:34 pm
Both programs have a way, within the preferences to stop them from loading on the boot. Further you can shoose to start either one manually as you choose.
In NextStart and in Workshelf its under Global preferences in each of the programs.
cef100
 Post subject: nextstart issue's..
PostPosted: Sat Mar 17, 2007 6:56 am
Thankyou cef100 for the advice..
i will write it down in my set-up book for future refrence..
got a memory like a siv... lol...
justin... :lol:
Users browsing this forum: Google [Bot], GPT [Bot] and 141 guests
