 Post subject: Problem with Module positioning ?
PostPosted: Sun Apr 08, 2007 8:56 pm
Using Atmospherica theme, I lock the position of a module. I then SAVE the theme. I open another theme. I then reopen the Atmospherica theme & the module is not in the previously locked position - it is in the "default" position at right-top of screen. What am I doing wrong??
BTW, would it be possible to have the memory hog displayed by the RAM meter?
PostPosted: Sun Apr 08, 2007 9:08 pm
Thanks for pointing this out, John - the module auto arrange feature (which you can turn off, by the way) - was not taking into consideration if the user had locked the position of a module. Fixed for the 7.4 release, thank you.
Your Memory Hog idea is actually a very good one too. :D
PostPosted: Sun Apr 08, 2007 9:11 pm
Glad I can be of some help after subjecting you to my Memory PITA.
Users browsing this forum: IvarR and 201 guests
