 Post subject: I'm new here
PostPosted: Fri Jul 13, 2007 3:34 pm
Hello everybody
I have one question and hopefully you'll be able to help me:P
what i should do when i download a new skin
I downloaded Apollo 1-0.zip and i got around 50 folders when i opened file...
How do i actually load theme ?
Thanks a lot for your time
Forgive me today is my first day using nextSTART :)
PostPosted: Sun Jul 15, 2007 8:31 am
From the Preferences window, you can enter the 'Theme Management' section. In there you will see an 'Import Theme' option. Click on that and locate the zip file. The theme will then be installed for you. No need to unzip anything yourself :)
I do that from WorkShelf personally.
http://www.scarebear.org/
Users browsing this forum: No registered users and 162 guests
