 Post subject: Weather Module Bug?
PostPosted: Sat Jul 14, 2012 8:12 pm
I have setup the weather module for my location Bozeman Mt and for all the T-Storm icon info. It only shows the ? icon and not the any of the thunderstorm icons that are in the folder. Win7 x64 SP1 Pro. Don't know if this is a bug or a problem on my end.
Win8 Pro x64
4TB HDD
2 GeForce 280 GTS in SLI
8GB DDR2 @1066z
Tri-Screen Setup
Nexus (free) v12.2
 Post subject: Re: Weather Module Bug?
PostPosted: Sat Jul 14, 2012 11:48 pm
I'm not sure if it's a bug either, but sometimes it depends on the theme and/or what style you choose. Of course it's possible that it could be an issue on your end, or sometimes it's the site that relays the info.
I just entered the location you gave and for today it says N/A for the first temp listed, and no lightning bolt as it shows on the site when I right-click on the module --> Detailed Weather Conditions.
I didn't pay attention before I changed it to yours, but after changing it back, the same issue in my location with the first temp in the list for today is showing N/A. It appears it could be something with the site properly relaying the info. It might clear up later on by tomorrow.
PostPosted: Sun Jul 15, 2012 1:31 am
I too get the N/A on the temperature in the first or current condition, at this time of day. In the current day and forecast icons, the two temperatures indicate forecast high and forecast low temperatures. It says N/A because it is later in the day, past the time for the forecast high temp. I noticed you posted your message at 5:48 PM [my time anyway], which is past when the forecast high would be.
That makes sense to me anyway. I haven't noticed this yet myself but if you check back in the morning, that N/A should turn to the forecast high temp for that day.
As for the OP, that might be theme related. I haven't experienced anything like that myself, and I have applied many themes to the temperature module.
PostPosted: Sun Jul 15, 2012 7:20 pm
Thanks for the info guys. Its still messed up for me but only on the T-Storm icons, the other are showing up. So i don't know wtf it is lol
Win8 Pro x64
4TB HDD
8GB DDR2 @1066z
Tri-Screen Setup
Nexus (free) v12.2
PostPosted: Mon Aug 13, 2012 7:13 am
Maybe you accidentally deleted one or more of the weather images?
Check out
C:\Users\Public\Documents\WinStep\Weather\Icons1\
and
C:\Users\Public\Documents\WinStep\Weather\Icons2\
How many images are in each folder? There should be 35 images in each folder, numbered 01 to 35.
PostPosted: Mon Sep 03, 2012 2:02 am
all fixed now, thanks. Re-DL the installer and now it has all 35 images.
Win8 Pro x64
4TB HDD
8GB DDR2 @1066z
Tri-Screen Setup
Nexus (free) v12.2
Users browsing this forum: Google [Bot] and 219 guests
