 Post subject: Great Program, Tiny Issue With Malwarebytes Pro
PostPosted: Tue Jul 30, 2013 2:28 pm
Hi there,
Just started using Nexus Dock and have to say it's much better than the last dock I used. Corner bumping is excellent. I always hated when docks and task bars popped up unwanted because I went to far down or up with my mouse. It was the computer equivalent of getting my sleeve caught on something :)
One thing I've noticed though is that Malwarebytes Pro running with real time protection doesn't show as running when I turn on the coloured indicators for running programs. Small niggle but any chance of a fix?
Thanks.
 Post subject: Re: Great Program, Tiny Issue With Malwarebytes Pro
PostPosted: Tue Jul 30, 2013 10:06 pm
On that last part, usually Antivirii (or Antiviruses, if you prefer), employ a different executable, usually a service or a DLL, for real-time protection, which is entirely different from the executable that runs the front-end. So, that's possibly why you don't see the indicator.
PostPosted: Wed Jul 31, 2013 12:14 am
Yes you were right. In the Malwarebytes folder when I put the application mbamgui instead of mbam into the dock it shows as running now.
Thankies :D
Users browsing this forum: Amazon [Bot], Google [Bot] and 214 guests
