 Post subject: Multiple monitors
PostPosted: Sat Feb 02, 2013 2:25 am
New user, using dual monitor and having trouble. I have my dock set to auto hide on monitor two, but if I am using a window on monitor one and mouse over the dock on monitor two, it will not come up unless I click on monitor two. Is there any way to fix this so the dock comes up, regardless of which monitor is active?
 Post subject: Re: Multiple monitors
PostPosted: Thu Apr 18, 2013 4:52 pm
I've been having a similar issue. I have a three monitor setup and my main monitor is in the middle but the dock will not show up unless I click or focus on monitor one. I never had these issues with rocketdock or objectdock. I even tried the z-order option in the settings but none of that helps. Does anyone have a solution?
PostPosted: Tue May 28, 2013 11:32 pm
I had the same problem with a two monitor setup and was only able to solve it by making the main program running on the monitor where the launcher was, a window, instead of running full screen. I manually sized it right up to the edge of the monitor so I didn't lose any space compared to running it full screen. After that, the Nexus launcher would respond properly.
Users browsing this forum: Amazon [Bot], Google [Bot] and 209 guests
